I Have add one manhole in between two existing manhole. Now I want to renumber this manhole as per flow direction or sequence of existing manhole.
How can I renumber this manhole.
For ex. (as shown in image);
I have draw manhole 1 to 6 number,
Now, I want to add one more manhole in between MH 3 to MH 4,
New number manhole is MH 10 as per continuous MH sequence,
I want to simply renumber this MH 10 as per continuous sequences towards MH 3 to MH 6.
Regards;
Rohit
Hello Rohit,
You can change the label of the manhole, by going to its properties.
If you want it to renumber it between MH 3 to MH 6, then you can change it to MH-4 and then also change labels of downstream manholes accordingly.
Also you can change the sequence of the labels of manholes by going to Tools>Options>Labeling
Sushma Choure
Bentley Technical Suppport
Thank You mam,
I have try with this manual properties method Its good and very easy. If I have a more number of manhole in my network then I thing it is not easy by change number by manually properties. so what can I do??
I have hear about the method for renumber by using grouping or something by layer etc... . exactly I dint know about this method.. Mam u a have any idea of this method for renumbering if I have may number of manhole.
Please suggest me.
What i can think of is once you have added manholes in the model, you can sort the manholes in the flex table from Upstream to Downstream and then renumber the manholes, this way it will renumber them in the order again.
Answer Verified By: Jesse Dringoli
