I delete a pair of inlets and anytime I try running the program it tells me there is a problem, that I should check my data. I checked my data and found a couple of pipes that I am not able to edit or delete. Is there something I can to fix this issue? I have try deleting the scenarios, the alternatives and any profiles I have made just in case but I haven't had any luck.
There might be an issue with your model's dwh file. Try the suggestions in the following article.
Some pipes or junctions in my model are not visible, but they are shown in my flextable OR Annotations or color coding are not correctly displayed.
If that doesn't fix your issue, then please provide the model files, the scenario you are computing and the labels for the elements you can't delete.
Sharing Hydraulic Model Files on the Haestad Forum
Craig Calvin
Bentley Technical Support
