How should i model major and minor losses at a heat exchanger?
The heat exchanger are linked with 100mm diameter pipe on both side shown in figure A.The internal and external diameter of Heat exchanger is 80mm & 100mm respectively. Inside the heat exhanger 4 Nos. 30 mm diameter stainless steel pipes are there(shown in figure B).
See also from our wiki:
Modeling devices and components that are not explicitly available as an element
