I have a question in automatic design of a sewer system or which I need a solution immediately. I am unable to get a valid pipe and gradient selection in automatic design. I attach the zip file of my model for a solution. I find that I am unable to attach the file or even give a name for this question. So, that itself is a question.
Aloy
Hello Aloy,
You can upload the model files using the link mentioned below.
Could you please elaborate the issue, are you not able to get the desired the velocity and slope in the model?
Here are some useful links about design constraints in the software.
Sushma Choure
Bentley Technical Suppport
Here is another article that might be helpful.
Troubleshooting Automated Design Results
Without looking at your model, I recommend checking all constraints in the Design Constraints Alternative.
Open the Conduit Catalog and make sure the boxes are checked for "Available for Design" where appropriate.
Craig Calvin
Bentley Technical Support
