This is my first time really playing with the hydrant feature on watergems.
A client is asking if there is a way to input
-Field data
-photos of the hydrant
-date installed
-type of hydrant ex. mueller
The more simple the explanation the better if possible. Thank you very much!
Answer Verified By: Alan Frygier
Hello Alan,
To know more about adding user data extensions to add the required fields like installation date, type of hydrant etc. in the properties of the elements, as mentioned by Dr. Tom Walski, please go through the below mentioned wiki's.
Importing data into installation year field
About entering field data, you can import the field data like flow, pressure, hydraulic gradient line, pump flow etc. into the model using the SCADAConnect tool, which imports the field data using different types of data sources like Excel, OPC, , oracle, ODBC, Access,SQL etc.
Please read more about SCADAConnect and importing field data into the model using the link mentioned below.
Also you can import the field data using tool Darwin Calibrator to compare the field data with the model data and also look for leakages in the system. You can export the results to scenarios from Darwin Calibrator based on field data and compare that with model data. Below is detailed information about the same.
Sushma Choure
Bentley Technical Suppport
