I have installed Bentley HAMMER from student server with an activation key. I need the Dataset to get strat with some descriptive and step by step hands-on, like I had it for WaterGEMS and SewerGEMS, with Solution and Starter folders. From where can I download the DATASET for Bentley Hammer.
Note: - I am having Lessons and Samples in "C Drive", but datasets are more simpler to get started with.
Hello Videet,
Assuming you have access to the Learn Server, you can find on-demand HAMMER training at the following link: HAMMER training. This will include data sets when they are required, which can be saved to your computer.
In addition, there are a few quick start lessons available with HAMMER. Assuming you have installed the CONNECT Edition, you can find these by going to File > Help > Quick Start Lessons.
Scott
Note that you can find other learning resources for HAMMER here:
Learning Resource Guide for new users of Bentley HAMMER
