My boss is currently having me research on how to do a UDF in watergems,
he wants to know if there is a way when doing this test on watergems if it will tell us which valves to open and close during the process so that it is possible for the direction to be only unidirectional like the test says.
Is wategems capable of this? or is there a separate program that will tell us which valves to open or close while doing this test?
Thank You
Answer Verified By: Alan Frygier
There is a feature on the flushing toolbar that can identify valves that, which should be closed to isolate the pipe run that has been selected. The feature is called "auto-isolate" and it automatically chooses the valves along the run to close. There is more information in this wiki on setting up a flushing analysis under the unidirectional flushing section.
Mark
