sort by upstream/downstream issue
i'm just trying to renumber the manholes in SewerGems v 8i SS4
and it just doesn't work.
any advice?
thanks
Parents Reply
  • Hello,
    The following support solution should help with the issue:
    http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/9054
    There is a Sort Upstream -> Downstream and Sort Downstream -> Upstream option in the right-click menu of the FlexTables. This should allow you to sort the manholes in the direction of flow.
    Scott Kampa
    Bentley Technical Support
