Flow (System Sanitary) or Flow (Known) for steady state
Hi
For a small sanitary network which has some service connections, steady state design should be done based on Flow (dry-System Sanitary) or Flow (Known)?
What is difference between both flows?
Hamid
  • Hamid,
    This wiki will explain known flows:
    https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/14202.understanding-known-flows
    The Flow (dry-System Sanitary) sounds like a reported field that would tell you the dry weather system sanitary flow that are being routed in the system. I'm saying it sounds like this is what it is because I can't find that exact field you are speaking of.
    The main difference between this field and the known flows is the Flow (dry-System Sanitary) are additive whereas an entered known flows overwrites known flows from upstream.
    Mark
    Mark
    Answer Verified By: Hamid.AKbari
  • To supplement what Mark said, usually you would design for peak flow conditions, typically using Extreme Flow Factors. These are modeled with Unit Load-based dry weather flows that are typically based on average conditions, with a peaking factor applied for design. Quick Start lesson 1 in the Help documentation explains the process of adding unit loads and extreme flow factors.
    You can also find some general modeling advice in our Wastewater Collection System Modeling and Design book:
    http://pages.info.bentley.com/books/?Book=Wastewater%20Collection%20System%20Modeling%20and%20Design
    Jesse Dringoli
    Bentley Systems, Inc.
