Why are my storm estimates so low in Pondmaker?
I am currently designing a basin in Pondmaker. Everything goes smoothly until I run my outlet design. When I do, the program estimates my storm elevations at a very low depth as seen in the first picture below. I then continue to route the storms through my pond, and the elevations immediately jump up (as seen in the second photo). My question is how can I get the program to accurately estimate the storm elevations?
  • Hello,
    In order to look into this, we will need to see a copy of the model files. There are two options for sharing your model files on BE Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
    http://communities.bentley.com/content/bentleysecurefilesupload.aspx
    If you upload the files to Sharefile, please post here so we know that they are available.
  • Hello Tim,
    This is likely related to some user notifications that you are getting when you compute the predevelopment cases. If you compute the 1-yr predevelopment scenario, you see that you have user notifications related to calculated and interpolated peak flows being greater than the default value of 1.5%. When this occurs, the reported flows may be different from what they should be. For instance, a peak may be occurring between time steps. The end results of this is that the results will be a little off from what you might expect.
    Here is a support solution on this issue:
    http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/7598.catchment-user-notification-about-the-difference-between-the-calculated-peak-flow-vs-interpolated-peak-flow-being-greater-than-1-5
    This can often be resolved by using a smaller output increment. For instance, I set the output increment in the calculation options to 0.05 hours. When I run PondMaker again, the results are better.
    I would recommend trying to find the right balance of results and computation run time to try to minimize this. You can see improved results using the output increment of 0.05 hours. Lower values still might yield even better results.
    Please let me know if you have any questions on this.
    Scott
    Answer Verified By: TimZ
