I have just started modeling with constituents. My question is what would be the best approach to modeling DBPs (i.e. THMs) in WaterCAD v8i SelectSeries 3? In the field, this would be a combination of chlorine levels, water age, seasonal temps (summer) etc... Would the best way be to find where in the model you have a combination of the high chlorine levels + high water age, and then create a constituent with a positive bulk reaction rate to represent growth and then to be dispersed from nodes in those areas? I am just having a hard time converting this to "model form" as I like to call it. Not sure how to factor temperature into this either, as high temps cause more problems. Any feedback would be greatly appreciated.
Thank you!!
You mentioned that you need WaterGEMS SELECTseries 5, can you perform it using WaterCAD as well?
Thank you in Advance!
Jacques Buzaglo
Support and Sales Manager Bentley Products
McKit Systems Ltd.
Hello Jacques,
Yes that's true you can perform the same using WaterCAD as well.
Here is difference between WaterCAD and WaterGEMS for your reference.
What is the difference between WaterCAD and WaterGEMS?
Also, here is wiki about modeling DBP formation in Water products.
Modeling DBP Formation - Water Quality Analysis
Sushma Choure
Bentley Technical Suppport
