Pipe Size Issue
Hi
As the following capture shows, when I turn on the label of the pipes it just show some numbers!
Also, in the notification message I get the following error:
Catalog conduit shape or material is different from the shape or material of the selected catalog conduit.
Hamid
  • Hello Hamid,
    The label that appears looks like the identifier you see in the Engineering Libraries or the conduit catalog. I would check the element label in the properties to make sure that it didn't get changed to the library ID value instead.
    The user notification about the mismatch is not something I have seen before. It isn't included in your screenshot either. Could you either upload the model as you have before (and please provide the name of the file to us so we know which file is your) or include a copy or screenshot of the user notification.
    Scott
  • Hamid,
    Try "Update Database Cache" and "Synchronize Drawing" under Tools > Database Utilities. If this doesn't help, please upload a copy of the model as suggested by Scott. (either attached to your reply, or using the Secure File Upload method)
    http://communities.bentley.com/help/w/be_communities_help/7079.communities-secure-file-upload
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
  • Hamid,
    Jesse Dringoli
