Design Catchbasin with fixed cover
Hi
is it possible to design the stomsewer network as catchbasins have a fixed cover as 1.2m but the manholes have 2m minimum cover?
Hamid
  • You can define the local pipe constraints for the pipes connected by catchbasins in the Design alternative. Means for those pipes set minimum cover to 1.2 m.
    And keep minimum cover to 3 m for the pipes connected by manholes.
    Sushma Choure
    Bentley Technical Suppport
    Answer Verified By: Hamid.AKbari
Reply
    Sushma Choure
