Multiple Storage pipe
Hi
According to the following link what if I have 3 storage pipe some thin like the following captured?
Note that, in the manual calculations I indicate the switching on-off table based on "minimum Volume Req for Cycling time=15xQxt", let give you an example:
design flow=0.4 m3/s , minimum cycling time=60sec ----> minimum volume for Cycling time=360 m3 ,
so I will see in the what elevation in the wet well I can get that volume (stored in the pipe and wetwell) then I will indicate the pump on level, but in the SewerGems user will indicate the on-off level without considering to these issues!
Thanks and look forward to hearing from you.
Hamid Akbari
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/19368.storage-volume-of-wetwell-and-pipe
  • If the pipe volume is significant, then per the Support Solution article, you may want to consider modeling it as part of the wetwell, by using the "variable volume" type. You could include the volume of all three pipes.
    Even if you decided to model them as conduits (like in your screenshot), the pump on/off elevations would be the same. (the elevations corresponding to the desired volume) If you used the conduit approach, you'd just have to make sure to externally calculate what that elevation would be, based on the pipe and wetwell sizes.
    Jesse Dringoli
    Bentley Systems, Inc.
  • 1-could you please let me know how can I define "Cross-Section Curve" field for the all three pipes and wetwell? (just give me an example please)
    2-assume that all pipes have different invert elevations in connection with wet well, it will be so difficult to calculate water stored in the pipes and wetwell when the water level reaches to the specific elevation in the wetwell?(be cause pipes have the slope! )
    Hamid
  • Hamid,
    If you would be kind enough to share your spreadsheet after you do that maybe it will help out another user who might find themselves in a similar situation until a tool is developed for SewerGEMS.
    Mark
    Mark
  • Sure I 'll do it, please ask to developer include the following into the pump stations :
    -minimum cycling time
    -minimum volume required in the cycling time
    -minimum level required for Level on/off (and users can increase if they want)
    -create a field for the design flow into the pump definition
    Hamid
  • Hamid,
    Since these are not requests that I've seen before, it is possible that other engineers in this situation use a different approach. Can you estimate the pump on/off elevations (for modeling purposes) without having to calculate volumes of the wetwell and storage pipes? Wouldn't the actual system operate based on wetwell level/HGL? The modeler typically has this information which is why SewerGEMS has fields for pump on and off elevation.
    If this is a new system that is being designed, you could estimate the control elevations, run the model, analyze the results (including cycle times), then adjust the controls from there.
    If this does not help, please provide a bit more details on the features you requested above and exactly how you envision that they would work.
    Jesse Dringoli
  • Hi Jesse
    I am just following the HEC-24 for stormwater pump station with storage pipe design.
    let tell you the steps to calculate the on/off level:
    1-you have the minimum cycling time=10 min and design flow =0.2 cms, so the minimum volume in the cycling time is V= 15 x Q x t = 30m3
    2-wet well section area is 20 m3
    3- the pump needs to evacuate at least 30m3, you should find out in which level wet well and storage pipe can provide 30m3 which is depends on storage pipe slope and number of storage pipe.
    the condition can be complicated if the number of pumps operating change or the pipes slope change.
    e.g. if two or three pumps works as parallel and imagine that you want to compare the parallel scenario with the scenario that each pipe discharges separately , it takes couple of weeks if you do it manually and SewerGems can't work you at all.
    Hamid
  • Enhancement # 183224 has been filed.
    Jesse Dringoli
    Answer Verified By: Hamid.AKbari
Reply Children
