PondPack Report Builder Wrapping of last column
Everyone,
I am using PondPack V8i [08.11.01.56].
When I generate a report using the Report Builder, it always wraps the last column underneath the table, as seen below.
I have tried all the things that Scott Kampa suggested in his post on the wiki http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/20428.the-columns-in-the-reports-created-from-report-builder-are-wrapping-around-to-the-next-line-how-can-this-be-adjusted however none of these worked.
So far I've:
  • Set my printer to Adobe PDF and attempted to print the report that way
  • Adjusted the margins numerous times (0.5in, 0.25in, 0in)
  • Adjusted the page size and layout (11x17 and landscape)
  • Exported the report to different formats (.csv,.txt, .html, .pdf)
When exporting the report to the different formats, I found that they still put the column under the table or they were formatted weird.
For example, in the .csv file, there is an open spot for the column, but it still places it under the overall table.
I also did the steps to provide the old PondPack output, however, it provided much more information that I needed.
The only thing I haven't done yet was start the program is Safe Mode, however I don't think I have administrative privileges to do this at work.
Any help would be appreciated.
TimZ
Parents Reply Children
