Hi Jesse,
I have read several of the forum posts and I cannot find anything to help me with my model.
I am working on a very simple model to obtain some rough discharge values. The model consists of an elevated reservoir connected to two other branching reservoirs at a lower elevation. I am evaluating a controlled discharge to one reservoir to observe how the discharge to the second reservoir changes based on controlling flow to the initial reservoir. I have attached a screen shot of the model so you may be able to get a better understanding.
The way I am modeling the system is by removing the "Arroyo Grande Reservoir" and replacing it with a junction with a set demand. I expected to see a change in the discharge to the "Terminal Reservoir" but that did not happen. I further troubleshooted and tried placing a FCV in P-1 to control the incoming flow and see if that caused the discharge to the "Terminal Reservoir" to change but that did not work either. I don't know what other way I could model this, or perhaps, if I am analyzing it incorrectly. If you have any suggestions as to how this may be achieved please let me know. If need be I can also send you the file. Thank you, in advance, for your help.
Best Regards,
AngieLopezLake Model.zip
