Bently PondPack V8i Problem - Adding engineering library from ProjectWise
I'm attempting to set up my project to work out of ProjectWise. I have my model set up and working fine, but I cannot get the engineering library containing my rainfall curve to load. When I attempt to add my library to my model using the "ProjectWise add existing library..." option, I get an error stating " The field is too small to accept the amount of data you attempted to add. Try inserting or pasting less data."
To make sure my .xml file was ok, I copied it to my desktop. Then I went into my model (Still using ProjectWise) and I was able to successfully load the library.
If you need a better explanation, please let me know.
TimZ
  • Hello,
    Thank you for the information. I was able to import the data into a model from ProjectWise, both existing storm and the XML file that you provided.
    Once the data was in ProjectWise, I added to the Engineering Libraries from within PondPack's Storm Event dialog. I selected Engineering Libraries > Import from Library. Only the Storm Event Groups option is available. I then selected New > ProjectWise Add Existing Library. I browsed to the file in ProjectWise and selected it. It was then available in Storm Event Groups, and could be added to the engineering library.
    You may want to try exporting one of the storms from a sample model, such as Bobcat.ppc. There is a storm there that can be saved into a test XML library file and moved to ProjectWise. You can then create a new model and try to import the storm from the Bobcat model (you won't need to create any elements or scenarios/alternatives for this test; just a fresh model with no storm data will be sufficient).
    If the issue still occurs, let me know what version of ProjectWise you have. Perhaps the issue is related to this or to your connection to ProjectWise.
    Scott
  • I attempted your steps, but unfortunately I still get the same problem.
    I am using ProjectWise Explorer V8i (SELECTseries 4) Version 08.11.11.590 - Commercial Release
  • Hello,
    Instead of copying and pasting, try dragging and dropping the file from your local drive to ProjectWise. Also, did you try the creating a new library from the storm event in a sample model as well?
    Scott
  • I tried both of those option, but I still receive the same error.
  • Do you know if you have PondPack and ProjectWise installed on another machine as well? If so, you could test the workflow there too, as this may be a machine-specific issue.
    If that doesn't help, we may need to do a screensharing session. If you could create a service request through Bentley's website, we can get started on that. You can create a service request at the following link: appsnet.bentley.com/.../index.aspx
    Scott
