The sewerCAD model is attached and the problem I have that I created selection sets and need to force the program to size the pipes in the selection sets (2 & 3 ) to be 200mm, so I create new catalog for the conduit " Only 200 " and I made 200mm is only available for the design and I specify the local pipe constrains for those selection sets, so I chose selection set > edit group> Conduit Table For Design (as in the flex table), then I global edit the conduit class to "Only 200" and global edit size to 200mm which is the only size available to design. When I run the model; The problem is the program change the catalog class to " Circle - PVC" and size the pipes accordingly to 150mm as in the " Circle - PVC" which does not needed in those two particular selection sets.
I guess there is an issue bemuse the program should lives with catalog assigned and the selected pipes for the design.
The reason I need to force the 200mm size because I am connecting to the existing system and need to use bigger size which has less slope " client recommendation"
Sewer Design.zip
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Mohd Azzam
You are right.. The problem has been resolved what about you Mohd Azzam
