how can I present the peak flow " Extreme Flow" calculated (the value at that particular location) in the output report "Flex Table" ? I guess we should be able to find out what is the calculated and multiplied value.
The client always asking about the base load and how the program calculates the extreme (peak) flow and what is the peak factor and needs to present those values in the report.
Regards..........MO
Mark
