Darwin Designer
I am practicing Darwin Designer, in Cost/ Properties Tab, I see two type new pipe that  one's cost optional Pipes and onother is Cost new. I don't know meaning of the line that content zero value for both Diameter and Unit Cost. I also can't understand how to self-explain the some of results is zero as well.
Please explain for me..
Thanks!
