Hi guys
I am having problems importing a LandXML into terrain model in sewergems. I am using a XML file created in Autocad 2014. The terrain model says the XML file is in the wrong format. Can sewergems use XML land files imported from autocad 2014? Is there any specific format the XML file must be in? I am using series 5 Sewergems.
Look forward to your response.
Craig
Could you please upload the screenshot of the error that you are getting while importing the .xml file as a terrain model source? It should not be a problem, if the .xml file is created in Autocad 2014. .xml is the correct format for importing the Landxml files. Could you please upload the .xml file for our testing? There are two options for sharing your files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley. communities.bentley.com/.../7079.be-communities-secure-file-upload If you send the file, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
Hello Craig,
When I imported the .xml as a terrain model, it took me almost half an hour to import the terrain model. But it dint give me any error as it gave to you. Instead it got imported as seen below.
We shall update you when we have more information about this particular Landxml file.
I have the same problem using SewerGEMS connect edition V10 and Civil 3D 2018, Is there any solution?
