StormCAD and LandXML not working
I have had the series 5 StormCAD installed recently however, the Trex function doesn't seem to load in landXML correctly anymore. The elevations are not coming in to the right coordinates. Can you please advise if this is an issue with the software? I previously didn't have any problems using Select Series 4.
Kind Regards,
Colm.
  • Does it give any error while loading the Landxml file using TRex, if yes then please attach a snapshot of the error.
    Did you check the units while importing the Landxml file?
    Sushma Choure
    Bentley Technical Suppport
  • Hi,
    It  gives the 'Features out of range' error (see screenshot). However, this error doesn't occur in the Series 4 version (I know this because a colleague is still using the series 4 version)
    Colm.
  • Hello Colm,
    I am having hard time finding your model in our sharefolder.
    Could you please upload the model again, and give us the name of the uploaded file. Please zip the files together.
    Sushma.
    Sushma Choure
  • Hi Sushma,
    I've uploaded a zip file again. File name is 'Bentley - LANDXML FIX' and contains two examples where the LandXML import does not work.
    1. Integration with ACAD example
    2. Select series 5 Bentley example
    Colm.
  • Hello Colm,
    We still seem to be having difficulty receiving your files. To check that there was not a problem with the upload system, I used the same link and uploaded a test file myself and it worked.
    When you fill out the form, browse to and select your file, then click the "upload files" button, you should see a progress bar popup, and then a green box should appear, stating that the files were uploaded successfully. Are you seeing this popup and confirmation? We'll reach out to you privately with an alternative method if needed.
    Jesse Dringoli
    Bentley Systems, Inc.
  • Hi Jesse,
    Yes files have been successfully uploaded (Green bar appeared - please checked for file name is 'Bentley - LANDXML FIX'.
    Kind Regards,
    Colm.
  • Hello Colm,
    Thanks for uploading the files.
    There was defect in StormCAD SS5 for importing Landxml files using TRex, which has been fixed with the patch. When I applied the latest patch for StormCAD SS5, I could import the elevations without any error.
    I request you to please submit a service request for this, so that we can provide you the patch. After applying the patch you should be able to import the Landxml file using TRex without any error.
    Sushma Choure
    Bentley Technical Support.
    Sushma Choure
    Answer Verified By: Jesse Dringoli
Reply
  • Hello Colm,
    Sushma Choure
    Sushma Choure
