I have had the series 5 StormCAD installed recently however, the Trex function doesn't seem to load in landXML correctly anymore. The elevations are not coming in to the right coordinates. Can you please advise if this is an issue with the software? I previously didn't have any problems using Select Series 4.
Kind Regards,
Colm.
Hello Colm,
Could you please send the model and the Landxml file to us, so that we can test it our end?
There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../7079.be-communities-secure-file-upload
If you send the model, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
