Hi everyone,
I am very new to this software and I hope someone can help me out with this problem:
I have a water distribution model which I would like to have a batch run process to analysis every node with 10 different flow demands and output the pressure and velocity of that node (and adjacent nodes) for a 24-hour period. The results (pressure & velocity of that node) can be outputted into txt or any other formats.
Is there a in-build function to do this batch-run process or others ways to work around it?
Your help will be much appreciated.
Thank you,
Shane
Sushma Choure
Bentley Technical Suppport
