SWMM Interface Files
I'm currently running a rather large model that has somewhat extensive hydrology, and I was looking at the option of using the SWMM interface files (rain file, runoff file, RDII file) to save the hydrological results so I don't have to rerun them every time I run the model.
In the calculation options I have it set to save the results for all 3 of these and have specified the file path, but after running it doesn't seem to save anything to this location. I'm assuming if I have it set to save it should save the results in the location I specify and then in future runs I can change this field to "use" to use the results that were previously calculated.
I can find very little information on these features for use in SewerGEMS. Do I have it set up right? Has anyone else encountered problems in using this feature?
David
Parents Reply Children
