Sewercad Profile scale englisgh units
In spite of the fact that sewercad project units are SI,  profile engineering is exported in English units.
  • Are you exporting the engineering profile into dxf format ? I tried exporting the engineering profile and the normal profile into dxf, and it got exported into the units which the model is having.
    What version of SewerCAD are you using? You can find the version no. by going to Help>About SewerCAD>number like 08.11.XX.XX in the down left corner. Also what is the version of AutoCAD you are having into which you are opening the exported engineering profiles?
    Make sure that you have the latest build of the software and the latest patch, which will hopefully resolve the issue. With a SELECT Service Agreement with Bentley, you can download the latest updates directly from Bentley's website.
    communities.bentley.com/.../8175.how-do-i-download-the-water-and-storm-sewer-product
    Sushma Choure
    Bentley Technical Suppport
  • If you are using the latest version, it would be good to know if this happens for all models or if it is specific to a given model. If it occurs for all models, please provide some screenshots of what you are seeing. Also let us know what the language and region settings are on the computer.
    If it is model-specific, we will likely need to see the model files. There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
    communities.bentley.com/.../7079.be-communities-secure-file-upload
    If you upload the files to Sharefile, please post here with the name of the file so we know it is available.
    Scott
  • Sewercad version is 08.11.05.58 64-bit
    Project is in SI units and exported dxf files is english units.
  • I already uploaded files, modelo_definitivo_pluvial_flores_oct_08.rar. It happens to all models.
  • I could reproduce the issue with the latest build of SewerCAD - 08.11.05.58. (which you already have). Please give us time to figure it out and to report it to our development team. This is happening only for engineering profiles not for the regular profiles.
    Sushma Choure
