Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
OpenFlows | Water Infrastructure
OpenFlows | Water Infrastructure Forum
How to move labels in profile?
Sign In
State
Verified Answer
Locked
Locked
Replies
Subscribers
83 subscribers
Views
Users
0 members are here
Offline
nkg2
over 8 years ago
Good evening, pretty simple question but not seeing where to find it. I have created a simple hydraulic grade versus elevation but the problem I am having is that several of my labels are sitting on top of each other. Is there a way to either manually move each label in the profile view or set a different offset and include arrows and leaders with them?
0
Offline
Sushma Choure
Mon, Oct 12 2015 5:38 AM
Please have a look at this support solution, it should help you.
communities.bentley.com/.../18267.can-i-move-the-labels-on-a-profile-for-watergems-if-they-overlap
Sushma Choure
Bentley Technical Suppport
Answer Verified By: nkg2
Cancel
Vote Up
0
Vote Down
Cancel
0
Offline
nkg2
Mon, Oct 12 2015 11:54 AM
in reply to
Sushma Choure
Yep it sure did. Thank you very much!
Cancel
Vote Up
0
Vote Down
Cancel
0
Offline
nkg2
Wed, Oct 14 2015 2:28 AM
in reply to
Sushma Choure
One more follow up question to this post is that I have found and have moved the markers where needed however they do not stay put and I have to move them back each time I want to look at a profile. Is there a way to lock it in? I do "Save Chart Options as Default" and still the markers are moved and I have to manually add drag markers each time. If this can't be done, I would ask that it is added in future releases.
Cancel
Vote Up
0
Vote Down
Cancel
0
Offline
MPachlhofer
Wed, Oct 14 2015 2:05 PM
in reply to
nkg2
What version of the software are you using? The version number can be found by going to HELP > About <Product Name> inside your program and locating the number in the lower left hand corner and may be in brackets. It should start like this 08.11.XX.XX where X are some numbers.
Mark
Mark
Cancel
Vote Up
0
Vote Down
Cancel
0
Offline
nkg2
Wed, Oct 14 2015 4:32 PM
in reply to
MPachlhofer
08.11.06.58, 64-bit Bentley WaterGEMS V8i, SELECTseries6
Cancel
Vote Up
0
Vote Down
Cancel
