Connection to Citect using SCADA Connect
I can successfully connect to our Citect server however when I try to pull historical data I get an error code 347 message. (I'm using WaterGems Select series 5)
Assertion did not succeed in user Cicode occurred when calling ctFindFirst(CTAPITrend( "08:47:00 ", "13/10/2015",464,1000,1,"RTU12_WTR_FLW_RT")) for signal RTU12_WTR_FLW_RT.
I can pull real time data from Citect into WaterGems but for some reason historical data is hit and miss. My theory is that it has to do with the date format in that Citect uses mm/dd/yyyy format while WaterGEMS uses dd/mm/yyyy format
Any assistance is greatly appreciated
Matt
Parents Reply Children
