Assume I have shape file of the project and in the shape file each plot labeled and have different population category (residential, worker, visitors ...etc.), how we can assign plots to the adjacent manhole and import the population and assign the unit load? is the sewergems capable for that? and how?
Thank you,
Mohamad,
You can use Loadbuilder for the spatial assignment, but it currently imports loads as the Pattern type (not unit load). There are some possible workaround though. See the below article, found in the Hydraulics and Hydrology wiki:
Using Unit Loads and Extreme Flow Factors after a LoadBuilder run
If your external file has a label field that matches the label of the manholes, you can import the loading information as Unit Loads using Modelbuilder:
Importing Loading Information Using ModelBuilder [TN]
