WaterCAD V8 XM-Import Excel
How can I import an excel file that contains flow data for each node?
Thank you!
  • Hello,
    You can use Modelbuilder to do this (under your Tools menu), using "Excel 8.0" as the source data type and "junction - demand collection" as the table type. Make sure your spreadsheet has columns for the junction label and base demand. If you have a column for the pattern label, make sure that you've defined those patterns inside your model first (Components > Patterns). You can link these to WaterCAD in the third Modelbuilder step.
    Jesse Dringoli
    Bentley Technical Support
    Jesse Dringoli
    Bentley Systems, Inc.
  • I've created a Technote on this subject on the Communities Wiki:
    Importing Demands From a Spreadsheet
    Jesse Dringoli
    Jesse Dringoli
Reply Children
