StormCAD Catchment Area
In my catchment area results flex table - there are cases where the Catchment Area is greater than the Scaled Area however I have specified a runoff coefficient of 0.6. Is this a calculation error and how do I resolve this? My model is currently designed for the larger catchment area which is oversizing the system.
Colm.
  • Hello Colm,
    I have tested and reproduced the behavior you described. A defect has been submitted and I emailed you the details.
    Update, 11/12/15: Defect was fixed and patch was provided.
    Craig Calvin
    Bentley Technical Support
    Answer Verified By: Craig Calvin
Reply
  • Hello Colm,
    Craig Calvin
