My branched network consists of near about 3000 junctions(nodes). I used Darwin designer for the above network with pipe dia varying from 15mm to 5000mm, results show that the Pressure at some nodes was as low as -12000MWC and the highest being 340 MWC. When I imposed pressure restrictions it shows Feasibility issues or no valid data as input.
I manually assigned dia to the pipes and results were quite satisfactory (in terms of pressure and velocity, dia being in the range mentioned above). I want to know the reasons for this and what should possibly do for this??
Could you please upload a copy of your model , so that we can have a look at it, to let you know reason behind this.
There are two options for sharing your model files on Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../7079.be-communities-secure-file-upload
If you send the model, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
