Ref: http://communities.bentley.com/products/hydraulics___hydrology/f/5925/t/111173
Two notes:
1- Have a look at attached model. Open Pipe Query-1. Difference between Flow defined in Query Builder and calculated Flow is 0.0000000001. Pipe P-226 is selected when Apply is clicked. If you set a value out of +-0.0000000001 (like 0.000000001) it can not find the pipe. It means the tolerance in Queries is likely 0.0000000001.
2- I want to make a Query for a Selection Set. WaterGEMS seems can not do it. Am I right? Do you have an idea to do this?
Query (Tolerance).rar
thanks.
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
Mike,
I believe the same suggestion that Jesse previously stated in the other forum thread will solve the problem. Using a query that searches for values less than a small value such as 0.01 should locate those values. (i.e. IdahoPipeResults_PipeDischarge (Flow) < 0.01 or IdahoPipeResults_PipeDischarge (Flow) < = 0.01).
If you wanted to use the = (equals) sign to search for exact values you could do that by using the unique values icon (see blue box) on the upper right side of the Queries window. This icon will only be clickable after you choosing a property (see red box) from the left hand portion on the window. The unique values will all be listed in the back box area in the unique values output portion of the window. From there you can double click on a value to choose that exact value.
Mark
