I am working on a WaterGEMS model within the ArcMap version, and am having issues editing my pipe/junction network. Tools like "merge nodes in close proximity" appear to be unavailable within the ArcMap version? Also, I am trying to disconnect a pipe from one junction and re-connect it to another junction without having to re-draw it. Doesn't look like I can do that either?
Hi Kristen,
Yes, I am in an edit session and using the WaterGEMS selection tool. Should I just be able to right click on a junction I want to merge and select "merge nodes in close proximity"? When I right click on a junction with the WaterGEMS selection tool I get the ArcMap options and not the WaterGEMS editing options that I would expect in the stand alone WaterGEMS version.
Is it possible that I my version of WaterGEMS and ArcMap aren't compatible? My WaterGEMS version is 08.11.06.58 and my ArcMap version is 10.2.2.3552.
Thanks for your help!
Chris
Chris Hathaway, PEProject EngineerCHA - Indianapolis, IN
Hi Chris,
I'm using the same versions you are for both, with an Editor-level license. When I right-click with the WaterGEMS selection tool, I get the WaterGEMS context menu. (I get the ArcMap context menu when using the ArcMap selection tool.) You could try re-running the integrator, but otherwise tech support may need to take it from here.
Kristen
You mentioned that you're right clicking with the WaterGEMS Selection tool. Can you confirm that you're using the one circled below in red? Using the same versions you have, I see the Merge Nodes option when right-clicking (after entering an Edit session).
