WaterGEMS properties menu in AutoCAD 2016
I can't get the WaterGEMS properties menu open to edit element information within AutoCAD2016.  When I double click on an element, the menu does not open as it normally would.  When I right click and try to select WaterGEMS properties nothing happens.  Any ideas?
