Conduit Catalog
Is it possible to specify a specific pipe diameter from a conduit catalog to a pipe For e.g., I have a network where I want the pipe size to be a minimum 315mm but in my catalog I have 250mm (because elsewhere in my network I want to size pipes at 250mm) so when I run my model the pipe size automatically sizes 250mm.
I understand for the whole model you can tick or untick the available to design in the conduit catalog but then my 250mm becomes 315mm or vice versa, the pipes I want to keep at 315mm become 250mm.
I could create an additional catalog and use that one for the 315mm pipes but I feel like this becomes messy. Any simpler solution?
Thanks in advance,
Colm.
Parents Reply Children
