Hi
Why Polyethylene (PE) pipes are not defined in WaterGEMS by default? Is it unhealthy or something else which must not be used for drinking water?
Who has information about using this kind of pipe or not using?
Mike
Hello Mike,
The following link explains how to add a material to the material library.
Modifying and adding entries to Engineering Libraries
Craig Calvin
Bentley Technical Support
