Series 5 to series 4 software
I have created a system in SewerCAD series 5 however it needs to be opened in series 4 by external client. Is this possible and how can this be done?
Thanks in advance,
Colm.
  • Colm,
    The model file can't be opened directly in Select Series 4 because our software is not forwards compatible. There are some suggestions in this wiki that can help you. 1) Have the external client upgrade to the version of the software that you're on. If they have a SELECT contract with Bentley the upgrade is included in their SELECT subscription. 2) You can export the model to a LandXML format and the client can import that 3) You can export all the model files and input fields to shapefiles using the outline in the forum post and they can use ModelBuilder to construct the model.
    communities.bentley.com/.../10184.can-a-model-be-saved-down-or-back-to-an-older-version
    Mark
    Mark
    Answer Verified By: Scott Kampa
Reply
  • Colm,
    Mark
    Mark
