I'm running a Chlorine residual analysis.
After each run completes I like to look at results for individual elements. To do this I right-click on a pipe or node, select "Graph" and the "Graph Series Options" box opens. In the "Fields" window (right hand side), "Pipe" is checked by default.
Is there any way to change the default? I would like to set a check box in "Results (Water Quality)" as the default. It's very time consuming to have to uncheck "Flow", then expand the "Results (Water Quality)" list, then check the parameter I want to view.
Craig Calvin
Bentley Technical Support
Answer Verified By: Gary Adams
Hi Gary,
You may be interested to know that we're adding a new feature called "Quick Graph" to the next versions of our Water, Storm and Sewer products. This allows you to see a graph of a desired result that stays open and will update as you click on a specific element in the model. When the next versions are released, we'll post an update on our blog along with an article detailing the new features. See the below article for more:
How can I find out when a new version or patch is available?
Jesse DringoliTechnical Support Manager, OpenFlows ProductsBentley Communities Site AdministratorBentley Systems, Inc.
