Greeting all ,
i got some problem when i trying insert background layer as DXF into Sewer Gems
SewerGems ver 8.11.05.58 64 bit
Cad civil 3d 2014 i use it to save my dwg ,
please provide any solution for using the background layer it is completely stopped.
t this error
Hi Sameh,
Please try the potential solutions in the following article.
Shapefile or DXF background "invalid or corrupt" error (Solution 500000071823)
If that doesn't help, please provide the model files, the DXF, and the error log. There is a link at the bottom of the error you are receiving that will display the error log. There are two options for sharing your model on Communities, whichever you choose please be sure to zip your files first. The first option is to attach the zip file containing your model to your reply on the forum using the Advanced Reply Editor (you'll find the link below and to the right of the reply box). If your data is confidential please use the instructions in the link below to send it via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley employees. Please be sure to reply on this thread with the name of the file after it has been uploaded.
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
Craig Calvin
Bentley Technical Support
