Bentley Annotation
When using annotation for conduit 'size' on a layout in Bentley - a string of random characters appears instead of showing the size of the conduit.
Can this issue be resolved?
Colm
Parents Reply
  • Colm,
    If the problem you're seeing matches what is mentioned in the last link that Sushma provided, you'll be happy to know that there will be an easier "fix" in the upcoming StormCAD CONNECT Edition. A new "Size (Display)" will be available, which can be used to display the size label for catalog conduits, instead of the ID that you see with the "Size" attribute. I have updated the article accordingly.
    Jesse Dringoli
    Bentley Systems, Inc.
