I am running a max day scenario in steady state and I am getting low pressures in several nodes. I would like to determine the pump settings that will increase the pressure at those nodes. So far the only method I have been using is to manually change the settings until I get the pressure I need.
Does watercad have an automatic tool that calculates the settings that would work?
