Lock pipes in waterGEMS.
Hi All,
I want to design a water distribution network which is having some existing old pipes, while designing i generally use global edit function, due to which the attributes of existing pipes are changing.
I want know that is their any option in WaterGEMS by which i can lock all attributes of  existing pipes. (other than making pipe active and inactive.
Thanks.
