Bentley Communities
Site
Search
User
Site
Search
User
Welcome
Products
Support
About
More
Cancel
Product Communities
More
OpenFlows | Water Infrastructure
OpenFlows | Water Infrastructure Forum
Guidelines to select diameter of pipes manually
Sign in
State
Verified Answer
Locked
Locked
Replies
Answers
1 answer
Subscribers
78 subscribers
Views
Users
0 members are here
Offline
Dilip Shreesh
Thu, Oct 6 2016 10:54 PM
I am a Student
0
Offline
Wayne Hartell
Fri, Oct 7 2016 1:25 AM
Hi Dilip,
The answer to this question will depend on what type of system you are designing and what the performance requirements and criteria are. So we can come at this from a starting point that will be useful to you, please let us know more about the type of design exercise that you are envisaging.
Wayne.
Answer Verified By: Dilip Shreesh
Cancel
Up
0
Down
Cancel
0
Offline
Dilip Shreesh
Fri, Oct 7 2016 4:04 AM
in reply to
Wayne Hartell
Thank you for reply. I am new and i want to learn how to select diameter in simple exercise. I want to work in Hydraulics and Hydrology. I am just beginners and i haven't any materials so.
Cancel
Up
0
Down
Cancel
0
Offline
Sushma Choure
Fri, Oct 7 2016 5:09 AM
in reply to
Dilip Shreesh
Hello Dipak,
Which software are you using?
As suggested by Wayne in his reply, please give us more details about type of project you want to design , design criteria etc. so that we can give suggestions accordingly.
Sushma.
Sushma Choure
Bentley Technical Suppport
Cancel
Up
0
Down
Cancel
0
Offline
Dilip Shreesh
Fri, Oct 7 2016 5:38 AM
in reply to
Sushma Choure
Thank you for reply. I am trying to learn watergems.
Cancel
Up
0
Down
Cancel
0
Offline
Wayne Hartell
Fri, Oct 7 2016 5:46 AM
in reply to
Dilip Shreesh
OK, if you are just trying to learn the software, good pipe diameters would be ones that are physically available. 2" is very small (and able to support low flow rates only) and 60" is very big and able to support very high flow rates (think enough water to supply a part of a city). The general rule would be to choose pipe sizes that do not have an excessive head-loss for the flow that is being put through them. A proxy for that value would be velocity. Too high a velocity in a pipe equates to high head-loss (more so if the pipe is rougher internally). So aim for no more than a few ft/s velocity and you are in the right ball park.
Cancel
Up
0
Down
Cancel
