I am doing the project on water distribution system.I want to skeleton the water distribution system. Existing water distribution system consist 749 pipes. Currently, I am analyzing network by using WaterGEMS, but we have an academic license which has pipe limit up to 250 pipes. Therefore I want skeleton the network up to 250 pipes. How to proceed it?
Please guide me
Waiting for your reply
Hello Madhusudan,
Please take a look at this article:
Can I run Skelebrator when my license limit has been exceeded?
You can indeed use Skelebrator to reduce the number of pipes in your model, even if the number initially exceeds your license limit.
If possible, you may also be able to split your model into multiple subsections each in their own model. This may only be appropriate in cases where you can make valid assumptions at the boundary/connection points so as not to skew the results of either model.
You can find more information about Skelebrator in the WaterGEMS Help documentation.
Please note that an Academic license is for academic use only. I assume the project you're working on is an academic project.
