SCADA simulation with imported demands
Hi!
My goal is to be able to choose any day for a EPS simulation without copy pasting my demand pattern.
I tried to set up a scada connect simulation (historic data source) for a one year period. I have calculated demands for the zone (from the in-outputs of pumps and tanks with 30 mins timestep), which I intend to use, because the deviation of demand is pretty high. Is there any way to import my calculated demand time series into the model?
It wouldn't be a problem, if I could give my pattern a starting DATETIME instead of TIME.
Best regards,
Attila
