Removing Multiple Sanitary Loads
I have multiple manholes with varying sanitary load counts.  I want to reset (globally edit) so each manhole has only one sanitary load with a Pattern Load - Base Flow and Pattern - Fixed assigned.
I can not do a global edit for that column in the flex table.  In the Sanitary Load Control Center if a manhole has 4 load counts assigned to it, it shows up 4 times.  Other than deleting each individually is there an easier way to global edit these all at once?  Ex. I want to reduce the number of load definitions for each manhole to 1.
Please let me know if you have any questions or need any additional information.
Vicki
  • Hello Vicki,
    The easiest way to achieve that would be to delete all the sanitary loads for all manholes from the sanitary load control center instead of deleting one by one manhole load.
    Select all the rows in the sanitary load control center as shown below and hit delete.
    Then initialize pattern loads for all the manholes and assign the values of base flow for the manholes so each manhole will have only one sanitary load count assigned.
    Sushma Choure
    Bentley Technical Suppport
    Answer Verified By: Jesse Dringoli
Reply
  • Hello Vicki,
    Sushma Choure
