EPANET Export/Import of WaterCAD
Hi!
I've exported a model from WaterCAD to EPANET .INP file. It seems like the [OPTIONS] the default flow unit is LPS no matter what my setting are in WaterCAD. The strangest thing is, that if I import it back to WaterCAD, Coordinate and Elevation units (and only these two) get reset to FEET, which is odd, considering that litre is SI related. If I change the units setting of the .inp file to CMH(m3/h), then the coordinate and elevation units stay set to meter.
Is this a known issue, or are there some options I might have missed before exporting to .INP?
Best regards,
