Hello
I have about 1500 taps that have referenced to the wrong conduits. Isit possible to update the reference links using model builder?
Craig Hill
Hi Craig - Yes. There is a separate tool called "Assign Taps to Links". You can configure it to re-assign taps even if they are already assigned to a link. In the CONNECT Edition, this is located under Tools > More.
See more information on this at the bottom of the following article:
Using LoadBuilder to assign Customer Meters to the nearest pipe using taps and laterals
