I would like to use VSP Type - Pattern Based in simulating my pumps. How to get the Pattern (Relative Speed) that is hourlly for 24 hours if I only have the target hourly pressure? I am using SELECT Series 5 Watergems. Thank you
Just to add to Stephen's response - I noticed you mentioned that you're using V8i SELECTseries 5. The "target head" control action was added in SELECTseries 6, so you'd need to upgrade. To learn more about other things we've added in later versions, check out the "What's new in..." articles at the bottom of this page:
WaterGEMS and WaterCAD TechNotes and FAQs
More on using controls to change target head:
Using controls to change the target pressure / HGL setting of a variable speed pump
There was also this recent forum discussion:
Modelling of Variable Frequency Drive
